How To Migrate the Ignition Loggers using Logback.XML
Comments
2 comments
  • Steven Tat
    Hello Wesley,
    Thank you for pointing that out. The article has been updated to reflect that more recent policy.
    2
  • Wesley Phan
    This code will give you a warning in the wrapper log, they have changed the trigger policy into a rolling Policy class now.
     <timeBasedFileNamingAndTriggeringPolicy
              class="ch.qos.logback.core.rolling.SizeAndTimeBasedFNATP">
    Here is the updated code with new policy.
    <rollingPolicy class="ch.qos.logback.core.rolling.SizeAndTimeBasedRollingPolicy"> <!-- Sets policy for generating and deleting log files -->
      <fileNamePattern>${LOG_HOME}\\TagHistoryQuery.%d{yyyy-MM-dd}.%i.log</fileNamePattern>
      <maxFileSize>10MB</maxFileSize> <!-- Max file size -->
      <maxHistory>10</maxHistory> <!-- Max 10 Days of History (Days is inferred from the value of fileNamePattern) -->
        <totalSizeCap>1GB</totalSizeCap> <!--Maximum sum of the log files' size -->
      </rollingPolicy>
    Chapter 4: Appenders (qos.ch)
    In versions prior to 1.1.7, this document mentioned a component called SizeAndTimeBasedFNATP. However, given that SizeAndTimeBasedFNATP offers a simpler configuration structure, we no longer document SizeAndTimeBasedFNATP. Nevertheless, earlier configuration files using SizeAndTimeBasedFNATP will continue to work just fine. In fact, SizeAndTimeBasedRollingPolicy is implemented with a SizeAndTimeBasedFNATP subcomponent.
    0
Please sign in to leave a comment.
This article has 2 comments.
