IGNITION INCLUDES AN IBM DB2 DRIVER, HOWEVER, IT WILL NOT WORK FOR ALL
IBM DATABASES. THIS ARTICLE EXPLAINS HOW TO CREATE A CUSTOM DRIVER IN
ORDER TO SUCCESSFULLY CONNECT TO IBM AS400 ISERIES DATABASE (QAS).
BACKGROUND
If you try to connect to an IBM A...
ISSUE: after upgrading the PostgreSQL database to v.10, the Ignition
Gateway log posts errors containing the
org.postgresql.util.PSQLException: Returning autogenerated keys is
only supported for 8.2 and later servers.
SOLUTION: update the JDBC driver fo...
THIS ARTICLE DESCRIBES HOW TO SET UP SIERRA WIRELESS AIRLINK RV50
DEVICE TO WORK WITH IGNITION SMS NOTIFICATION MODULE. IN SUCH A SETUP,
THE PURPOSE OF AIRLINK RV50 IS TO SEND AND RECEIVE SMS MESSAGES.
ESSENTIALLY, IT IS GOING TO BE UTILIZED AS AN SMS GA...
Ignition 7.9 supports Java 6, 7, 8, and 9. Java 10 is not supported
with Ignition 7.9. Unfortunately, Ignition can’t effectively support
Java 6 and 7 while simultaneously supporting Java 10 due to recent
changes in Java. Since we are committed to supporti...
