As of Ignition 8, 32-bit Vision Client support was dropped; the availability of 32-bit Java Runtime Environments (JRE) will diminish over time as the technology is slowly deprecated.
However, in an effort to aid architectures making heavy use of 32-bit hardware, Ignition 8.0.3+ includes some batch and bash scripts that can be used to launch 32-bit Clients. These launchers are unsupported, but are useful in cases where 32-bit Vision Clients are the only option.
Prerequisites
The following steps must be repeated on each piece of hardware that will run a 32-bit Client.
Install a JRE
The hardware that will run Vision Client must have a 32-bit Java 11 JRE installed. Earlier versions of Java (e.g., Java 8, Java 9, etc.) will not work.
You're free to use your vendor of choice, but as a suggestion, AdoptOpenJDK has some 32-bit versions (as of the time of this writing).
Set JAVA_HOME to the JRE
This step varies based on the operating system that will be running the Client. A quick web search should show you how to do this: "debian set java_home" or "windows set java_home"
Legacy Launchers
Using the Legacy Launchers involves retrieving a "legacyClient" file via one of the means listed below (based on operating system of the computer that will run the Client)
Linux & Mac
Download the legacy launcher
Run one of the following commands to download the legacyClient.sh file, replacing localhost:8088 with the address of the Gateway that's hosting the Vision project you wish to launch.
curl -o legacyClient.sh "http://localhost:8088/system/nativelaunch?type=legacy&os=linux"wget -O legacyClient.sh "http://localhost:8088/system/nativelaunch?type=legacy&os=linux"
Run the LaunchClient file from terminal. The launcher will attempt to download a JAR from the Gateway that will be used to run the Vision Client.legacyClient.sh address=GATEWAY_ADDRESS scope=SCOPE windowmode=WINDOW_MODE project=PROJECT certificate=CERTIFICATE
- GATEWAY_ADDRESS: The full address to the Gateway
- SCOPE: The Scope to launch, 'D' for Designer, 'C' for Vision Client (Note: without single quote)
- WINDOW_MODE: The Window Mode to use, 'W' for windowed, 'F' for fullscreen.
- PROJECT: The Name of the Project to Launch. A project by the name specified here must exist on the Gateway before attempting to launch the Client.
- CERTIFICATE: The PEM certificate file to use with curl or wget. (curl is attempted first, wget if curl is not installed)
- SKIP_CERT_CHECK: If this arg is supplied, certificate checking by curl or wget will not occur
- JAVA ARGS: Any java args. (NOTE: No checking is done on validity before attempting to launch)
Example Launch Commands
./legacyClient.sh address=http://localhost:8088 scope=D./legacyClient.sh address=http://localhost:8088 scope=C project=testing windowmode=F -Djavaws.launchparams="LaunchTag;LaunchTag2" -Djavaws.launchparam.LaunchTag="AAA" -Djavaws.launchparam.LaunchTag2="ZZZ" -Xmx2048M./legacyClient.sh address=https://Ignition:8043 scope=D certificate=mycert.pem./legacyClient.sh address=https://Ignition:8043 scope=D skipcertcheck
Windows
Download the Legacy Launcher
Using a web browser, visit the http://{gatewayAddress}:{gatewayPort}/system/nativelaunch?type=legacy&os=windows to download the legacyClient.bat file.
Replace {gatewayAddress}:{gatewayPort} with the address of the Gateway that's hosting the Vision project you wish to launch.
Usage
Run the LaunchClient file from command line. Running it for the first time on a system will take a moment, as the launcher has to download some necessary files from the Gateway first.
launchClient.bat GATEWAY_ADDRESS SCOPE PROJECT WINDOW_MODE ARGUMENT_FILE
PROJECT: The Name of the Project to Launch (
myProjectin the examples below) - WINDOW_MODE: The Window Mode to use, 'W' for windowed, 'F' for fullscreen. (Note: Must be specified when including an argument file)
- ARGUMENT_FILE: A File that contains additional Java arguments. Must be all on the first line with spaces between arguments. No formatting or validation is performed.
legacyClient.bat http://localhost:8088 DlegacyClient.bat http://localhost:8088 C myProjectlegacyClient.bat http://localhost:8088 C myProject Fcmd.exe /c legacyClient.bat http://10.10.70.68:9500 C myProject W C:\Users\myUser\Desktop\args.txt
A Word on SSL/TLS
SSL/TLS support is only available on Linux/Mac OS X for these launchers. Should a user wants to enable this feature, they must modify the legacyclient.bat to not download the launchclient.jar each time.
To Convert cert to a PEM cert for curl or wgetopenssl x509 -inform der -in certs.der -out certs.pem
NOTE: you still need to have the x509 certificate in the ~/.ignition/clientlauncher-data/certificates directory
Comments
0 comments
Please sign in to leave a comment.
