This article covers loggers related to Databases that were introduced in Ignition version 7.8.X.
Loggers in this article:
DatabaseConnectionManager
A series of loggers for monitoring database connections and individual queries.
DatabaseConnectionManager.{DatabaseConnectionProfileName}
- Logger where {DatabaseConnectionProfileName} is denoted as the name of an existing database connection profile. This logger will report any connection issues sent back from the database server itself.
DEBUG log that provides the error sent back from a failed connection to a MySQL database:
Database connection validity test failed.
com.mysql.cj.jdbc.exceptions.CommunicationsException: Communications link failure
The last packet sent successfully to the server was 0 milliseconds ago. The driver has not received any packets from the server....
Caused by: com.mysql.cj.exceptions.CJCommunicationsException: Communications link failure
Caused by: java.net.ConnectException: Connection refused: connect
DatabaseConnectionManager.{DatabaseConnectionProfileName}.Selects and DatabaseConnectionManager.{DatabaseConnectionProfileName}.Updates.
{DatabaseConnectionProfileName}.Updates are also provided per database connection. These allow you to monitor specific queries down to the exact syntax being executed against a database. It will not provide values of dynamic parameters.
TRACE log from Updates showing the full query entered from the Database Query Browser:
INSERT INTO test_table (NAME, TIMESTAMP) VALUES ('Taron','Wed Apr 24 09:11:47 PDT 2019')
TRACE log from Updates showing the full query entered from the Database Query Browser with an illegal insert to an ID column. (Note: again, there is no warning of bad syntax stated in the logs, but the full query is still reported):
INSERT INTO test_table (ID, NAME, TIMESTAMP) VALUES (3,'Taron','Wed Apr 24 09:11:47 PDT 2019')
TRACE log from Updates showing INSERT and UPDATE to tag history tables:
UPDATE sqlth_sce SET "end_time"=? WHERE "scid"=? and "rate"=? and "start_time"<=? and "end_time">=?
INSERT INTO sqlt_data_1_2021_10("tagid", "intvalue", "floatvalue", "stringvalue", "datevalue", "dataintegrity", "t_stamp") VALUES(?,?,?,?,?,?,?) [Batch x1]
TRACE log from Selects showing a SELECT statement for a running, real-time Easy Chart trending Tag history:
SELECT "tagid","intvalue","floatvalue","stringvalue","datevalue","t_stamp","dataintegrity" FROM sqlt_data_1_2021_10 WHERE "t_stamp">=? and "t_stamp"<=? and ("tagid"=?) ORDER BY "t_stamp" ASC, "tagid" ASC
TRACE log from Selects that shows a default logger accompanying FaultedConnectionRetryDaemon for testing valid database connections. A simple SELECT will also be running every 10 seconds:
SELECT 1
DatabaseConnectionManager.FaultedConnectionRetryDaemon
- Monitors connection tests being made to existing databases every 10 seconds. Expect to see both an attempt to connect and a result of that test.
DEBUG log showing a successful connection request and response to an existing database server:
Running test for datasource "{DatabaseConnectionProfileName}" (Current status = Valid)
Completed test for datasource "{DatabaseConnectionProfileName}" in 0 ms, status is now: Valid
DEBUG log showing attempts to communicate to an existing, faulted connection. This log typically appears before the result of {DatabaseConnectionProfileName} when it returns an error:
Running test for datasource "{DatabaseConnectionProfileName}" (Current status = Faulted)
Comments
0 comments
Article is closed for comments.
