This article covers loggers related to DNP3 device connections that were introduced in Ignition version 7.8.X.
Loggers in this article:
xopc.drivers.dnp3.Dnp3Driver
A series of loggers monitoring connection status and Tag subscriptions using DNP3.
- Show the output of the connection when it is first established.
- DEBUG log showing a successful, default device connection when it is first created, then disabled in the Ignition config. {DeviceConnectionName} is denoted as the name of the specific DNP3 device connection in the Ignition config:
Device {DeviceConnectionName}: Transitioning to Active state...
Synchronizing Dnp3 outstation…
Reading outstation conformance level...
Found outstation conformance level 0x33
Setting outstation conformance level: 3
Checking time synchronization...
Checking restart bit...
Unsolicited messaging remaining disabled on startup.
Shutting down Dnp3 driver…
Canceling integrity poll request on shutdown.
Clearing nodes on shutdown.
Disconnecting dnp3 master...
Disconnected.
xopc.drivers.dnp3.Dnp3SubscriptionModel
- Provides information about created/removed Tag subscriptions for DNP3 device connections.
- DEBUG log for created Tag subscriptions where {count} is denoted as the number of tags being created. {pollRate} is denoted as the Tag Group/Scan Class used for those sets of Tags. The device is then later disabled:
Optimizing and scheduling {count} items.
Scheduled 7 requests @ {pollRate}ms.
Optimizing 0 items to run once.
Shutting down Dnp3 subscriptions.
xopc.drivers.dnp3.requests.IntegrityPollRequest
- A logger notifying us when the driver attempts to poll from any existing Tag subscriptions on a DNP3 device.
- DEBUG log stating a poll request. A response to this log typically comes from the DEBUG output of drivers.dnp3.Dnp3SubscriptionModel:
Executing integrity poll request.
xopc.drivers.dnp3.Master
A series of loggers also monitoring connection status and Tag subscriptions using the DNP3. Provides more details about the specified parameters defined on the device connection in Ignition configuration.
- Shows details between the DNP3 driver and the outstation when connecting, established, and disconnecting.
- DEBUG log showing interaction between the driver and outstation when connecting, established, and disconnecting. For this example, Unsolicited Messages Enabled was set to false for the device connection. {sourceIP}/{sourcePort} and {destIP}/{destPort} are denoted as the Ignition server and DNP3 device IP and port numbers used for establishing a connection:
Modifying unsolicited: DISABLE_UNSOLICITED
requesting permit for DISABLE_UNSOLICITED
acquired permit for DISABLE_UNSOLICITED
[[id: 0x71bca2d2, L:/{sourceIP}:{sourcePort} - R:/{destIP}:{destPort}]] response [functionCode=RESPONSE,
indicators=[CLASS_1_EVENTS, CLASS_2_EVENTS, CLASS_3_EVENTS, EVENT_BUFFER_OVERFLOW]]
requesting permit for READ
releasing permit for DISABLE_UNSOLICITED
released permit for DISABLE_UNSOLICITED
acquired permit for READ
[[id: 0x71bca2d2, L:/{sourceIP}:{sourcePort} ! R:/{destIP}:{destPort}]] channel inactive
Canceling pending request.
xopc.drivers.dnp3.Master.ChannelManager
- Provides information regarding the connection between Ignition and the DNP3 device.
- INFO log that appears by default when the connection is established. {sourceIP}/{sourcePort} and {destIP}/{destPort} are denoted as the Ignition server and DNP3 device IP and port numbers used for establishing a connection:
[[id: 0x71bca2d2, L:/{sourceIP}:{sourcePort} - R:/{destIP}:{destPort}]] connected
- DEBUG log also providing information about the established connection:
Channel bootstrap succeeded: localAddress=/{sourceIP}:{sourcePort}, remoteAddress=/{destIP}:{destPort}
Comments
0 comments
Article is closed for comments.
