This article covers loggers related to Omron device connections that were introduced in Ignition version 7.8.X.
Loggers in this article:
ignition.drivers.omron.nj
A series of loggers monitoring connection status and Tag subscriptions using the Omron driver.
ignition.drivers.omron.nj.NjDriver
- Shows the output of the connection when it is first established.
- DEBUG log {DeviceConnectionName} is denoted as the name of the specific Omron device connection in the Ignition config:
Device {DeviceConnectionName}: Transitioning to Active state...
ignition.drivers.omron.nj.SubscriptionModel
- Provides a count of all existing Tag subscriptions for the device and a count of requests for each Tag Group/Scan Class being used for the Omron driver.
- DEBUG log successfully providing a count of all existing Tag subscriptions for the device and a count of requests for each Tag Group/Scan Class being used:
Optimizing and scheduling 19 items.
Scheduled 1 requests @ 1000ms.
ignition.drivers.omron.nj.requests.ReadArraysRequest
- Monitors all Tag subscriptions connected to array data types defined on the Omron device.
- TRACE log showing the current state of array Tags. Will log at the rate of the Tag Group/Scan Class. {opcitempath} is denoted as the item path defined for the existing Omron Tag subscription:
{opcitempath} = [Ljava.lang.Boolean;@7b90bb04
{opcitempath} = [Ljava.lang.Boolean;@6169696c
{opcitempath} = [Ljava.lang.Boolean;@29b6dc91
ignition.drivers.omron.nj.requests.ReadScalarsRequest
- Monitors all Tag subscriptions connected to non-array data types defined on the Omron device.
- TRACE showing the current value of non-array Tags. Will log at the rate of the Tag Group/Scan Class. {opcitempath} is denoted as the item path defined for the existing Omron Tag subscription:
{opcitempath} = 0
{opcitempath} = 99
{opcitempath} = !"#$%&'()*+,-./0123456789:; <=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\]^_`{|}~
{opcitempath} = 4.9239326
ignition.drivers.omron.nj.requests.optimizer.ReadOptimizer
- Summarizes the count of both array and non-array type subscriptions as well as the number of optimized requests.
- DEBUG log stating the count of both array and non-array type subscriptions. Also stating the number of requests:
Optmized READ: 19 scalar, 2 array, 0 partial array items -> 2 request(s).
Comments
0 comments
Article is closed for comments.
