This article covers loggers related to Modbus device connections that were introduced in Ignition version 7.8.X.
Loggers in this article:
- drivers.ModbusDriver2[{DeviceConnectionName}]
- drivers.modbusDriver2[{DeviceConnectionName}].BasicTransactionProcessor
- drivers.ModbusDriver2[{DeviceConnectionName}].SocketIODelegate
drivers.ModbusDriver2[{DeviceConnectionName}].ReadCoilsRequest
drivers.ModbusDriver2[{DeviceConnectionName}].ReadDiscreteInputRequest
drivers.ModbusDriver2[{DeviceConnectionName}].ReadHoldingRegistersRequest
drivers.ModbusDriver2[{DeviceConnectionName}].ReadInputRegistersRequest
- drivers.ModbusDriver2[[{DeviceConnectionName}].RequestSchedule
A series of loggers monitoring connection status and Tag subscriptions using the Modbus TCP driver. {DeviceConnectionName} is denoted as the name of the specific Modbus device connection in the Ignition config.
- Shows the output of the connection when it is first established.
- DEBUG log showing a successful device connection when it is first created, then disabled in the Ignition config:
Acquired connect permit, calling connect().
Disconnected -> Connecting
Releasing connect permit.
Connecting -> Connected
Connected -> Disconnecting
Disconnecting -> Terminated
- Provides information about created/deleted Tag subscriptions for a specific Modbus TCP device connection.
- DEBUG log for created/restarted Tag subscriptions where {count} is denoted as the number of Tags being created/restarted.
Processing transaction with sequence {...}
Adding {count} items.
Notifying callback of new subscription state: SubscriptionItem[{count}]
- TRACE log for an individual Tag subscription that was created/restarted. {...} is the specific Modbus TCP Tag name defined on the provider:
Adding {...}
Creating AggregateSubscriptionItem for {...}
- Shows additional details regarding the output of the connection when it is first established and also during an active connection.
- DEBUG log showing a successful device connection when it is first created, then disabled in the Ignition config. Instead of a device name being provided, we are instead shown the specific hostname and port defined in the Modbus device connection in Ignition config:
[hostname=10.10.60.75,port=502] Opening TCP connection...
[hostname=10.10.60.75,port=502] TCP connection successfully opened.
- TRACE log showing data being sent during an active Modbus connection. Will log every few seconds:
[hostname=10.10.60.75,port=502] Sending ByteBuffer [ 00 04 00 00 00 06 00 01 00 00 00 01 ]
- Monitors the read request and response of coil registers at the rate of a tag's tag group / scan class
- TRACE log showing a successful read request to a modbus device's coil register. In this example, a single tag is created for coil 1:
Sending message: [ 0B 71 00 00 00 06 00 01 00 00 00 01 ]
Received message: [ 0B 71 00 00 00 04 00 01 01 00 ]
- Monitors the read request and response of discrete input registers at the rate of a tag's tag group / scan class
- TRACE log showing a successful read request to a modbus device's discrete input register. In this example, a single tag is created for discrete input 1:
Sending message: [ 14 BC 00 00 00 06 00 02 00 00 00 01 ]
Received message: [ 14 BC 00 00 00 04 00 02 01 00 ]
- Monitors the read request and response of holding registers at the rate of a tag's tag group / scan class
- TRACE log showing a successful read request to a modbus device's holding register. In this example, a single tag is created for holding register 1:
Sending message: [ 15 6A 00 00 00 06 00 03 00 00 00 01 ]
Received message: [ 15 6A 00 00 00 05 00 03 02 00 00 ]
- Monitors the read request and response of input registers at the rate of a tag's tag group / scan class
- TRACE log showing a successful read request to a modbus device's input register. In this example, a single tag is created for holding register address 1:
Sending message: [ 15 F7 00 00 00 06 00 04 00 00 00 01 ]
Received message: [ 15 F7 00 00 00 05 00 04 02 00 00 ]
drivers.ModbusDriver2[{DeviceConnectionName}].RequestSchedule
- Provides a count of tag subscriptions being consolidated into a separate count of read requests.
- DEBUG log successfully providing a count of tag subscriptions being consolidated into a separate count of read requests:
Optimized 4 items into 1 read requests.
Created new schedule for 4 items in 0ms.
Size of new schedule before optimization: 1
Canceling 0 ScheduledRequests.
Adding 1 new ScheduledRequests.
CRC match. correct == current (2928945580 == 2928945580).
Posting 1 ScheduledRequests.
drivers.ModbusOverTCPDriver[{DeviceConnectionName}]
A series of loggers monitoring connection status and Tag subscriptions using the Modbus RTU over TCP driver. The sub loggers provided are stuctured exactly the same as drivers.ModbusDriver2[{DeviceConnectionName}] listed above
Comments
0 comments
Article is closed for comments.
