This article covers loggers related to OPC-UA that were introduced in Ignition version 7.8.X.
Loggers in this article:
DriverVariableNode[{DeviceConnectionName}]
- Monitors the current state of all Tag subscriptions for a specific device connection. Will update at the rate of the defined Tag Group/Scan Class for each tag. {DeviceConnectionName} is denoted as the name of the specific device connection in the Ignition config.
- TRACE log providing the current qualified value of a specific Tag subscribed to a device. nodeId will provide the OPC Item Path of existing Tags:
Driver setting value value=11644, status=StatusCode[Severity=Good, Subcode=NotSpecified], source=Tue Sep 14 15:10:14 PDT 2021,
server=null on DriverVariableNode@6d528c74[nodeId=[{DeviceConnectionName}]C5:0.ACC,nodeClass=Variable,dataTypeId=ns=0:i=4]
xopc2.client.OpcUaConnection
A series of loggers that will monitor the creation and value change of tag subscriptions for an OPC-UA client.
xopc2.client.OpcUaConnection$UaSubscriptionChangeListener
- Monitors the creation of Tag subscriptions when an OPC-UA server is started/restarted.
- DEBUG log of a successful subscription of 11 Tags for an existing Scanclass:
Synchronizing subscriptions...
Creating subscription 'Scanclass 'Default[default]'' @ 1000ms...
Creating/deleting items on subscription 'Scanclass 'Default[default]''...
nodesToAdd.size()=11
nodesToRemove.size()=0
Creating 11 items on subscription 'Scanclass 'Default[default]''...
Setting MonitoringMode to Reporting for 11 of 11 items on subscription 'Scanclass 'Default[default]''...
synchronizing subscriptions finished in 5ms. Re-synchronization scheduled=false
- TRACE log showing an example of a failed attempt to subscribe to a specific tag. id provides the OPC Item Path of an existing Tag:
Failed to create item 'NodeId{ns=1, id=[Micrologix]B3:6}': StatusCode{name=Bad_NodeIdUnknown, value=0x80340000, quality=bad}
xopc2.client.OpcUaConnection$DataValueConsumer
- Monitors all value changes occurring on existing tag subscriptions in the OPC-UA server.
- TRACE log showing an example of a Tag subscription that recently received a value change:
nodeId=NodeId{ns=1, id=[Micrologix]B3:0}, clientHandle=8, value=15
org.eclipse.milo.opcua.stack.client.handlers.UaTcpClientAcknowledgeHandler
- Monitors the request and acknowledgment of an initial connection to an OPC-UA server.
- DEBUG log showing a successful connection to the Ignition OPC-UA server. Provides the IP and ports being used.
Sent Hello message on channel=[id: 0xeceae68b, L:/127.0.0.1:58681 - R:localhost/127.0.0.1:4096].
Received Acknowledge message on channel=[id: 0xeceae68b, L:/127.0.0.1:58681 - R:localhost/127.0.0.1:4096].
OPC-UA Server.ActivateSessionService
- By default (logger set to INFO), provides details on the user credentials being applied to an initialized OPC-UA server connection.
- INFO log showing a successful authentication to an OPC-UA server:
User "{schedule=Always, firstname=, notes=, language=null, username=opcuauser, lastname=}" connected.
Comments
0 comments
Article is closed for comments.
